[Contest] LEGO Summer Vignette 2012
Vote, View and participate in our LEGO Contests to win awesome LEGO prizes.
djanscak
Re: [Contest] LEGO Summer Vignette 2012
Post by djanscak » Thu Aug 16, 2012 5:36 pm
I interpreted this as 10x10 studs, given that studs is the standard unit of measure in Lego. As to fitting 300 pieces on a 10x10 stud plate, it all depends on the pieces! I've got a vignette in mind but I'm yet to start building, mainly because I need to rip a bunch of pieces off my son's built sets. If I'm quick, he might not notice...
zhouston
Post by zhouston » Fri Aug 17, 2012 10:15 pm
djanscak wrote:I need to rip a bunch of pieces off my son's built sets. If I'm quick, he might not notice...
Haha, true AFOL right there...
Ice
Administrator
Administrator
Post by Ice » Fri Aug 17, 2012 10:57 pm
cornbread wrote:
*]Baseplate must be 10X10 (you can connect pieces to make a 10X10 plate)
Is that supposed to be 10x10 studs? For some reason I read that as 10x10 inches which is a 32x32 stud plate! I was thinking... how would you fit 300 pieces onto a 10stud plate, it must be 32x32! DOH!
Hi cornbread. djanscak is right and should be 10x10 studs, not 10x10 inches. :)
djanscak wrote:I interpreted this as 10x10 studs, given that studs is the standard unit of measure in Lego. As to fitting 300 pieces on a 10x10 stud plate, it all depends on the pieces! I've got a vignette in mind but I'm yet to start building, mainly because I need to rip a bunch of pieces off my son's built sets. If I'm quick, he might not notice...
cornbread
Noble Citizen
Noble Citizen
Post by cornbread » Fri Aug 17, 2012 11:00 pm
I blame the summer heat... it fried my brain.
CarsonHart
Post by CarsonHart » Sun Aug 19, 2012 9:36 pm
I have a quick question. It says it has to be a 10x10 base, but would it be okay if it still stayed in that size, but a different shape? What I mean by that is that it would still have 100 studs on the base, just like the 10x10.
Legobrandon
Post by Legobrandon » Mon Aug 20, 2012 2:42 pm
Same question as CarsonHart, am I allowed to build on a baseplate, but keep it confined to a 10x10 area. It will probably be marked with some bricks or tiles.
CarsonHart
Post by CarsonHart » Mon Aug 20, 2012 5:16 pm
My question is different though. I am not building on a baseplate, I just want to see if we have to build on a 10x10 square, or if we can build on a different shape base, as long it uses 100 studs.
Ice
Administrator
Administrator
Post by Ice » Tue Aug 21, 2012 11:07 am
CarsonHart wrote:I have a quick question. It says it has to be a 10x10 base, but would it be okay if it still stayed in that size, but a different shape? What I mean by that is that it would still have 100 studs on the base, just like the 10x10.
Hi Carson. No, you can't build it in a different shape even if the perimeter and area is the same. The base must be 10x10.
Legobrandon wrote:Same question as CarsonHart, am I allowed to build on a baseplate, but keep it confined to a 10x10 area. It will probably be marked with some bricks or tiles.
Hi Legobrandon. As long as the base is 10x10, its really up to you on what bricks to use.
CarsonHart
Post by CarsonHart » Fri Aug 31, 2012 10:22 pm
I just had a question about the base. You said that it had to be a 10x10 base, but there are some that don't follow that rule. Also, some have quick a bit of overhang. I'm just wondering, is that allowed?
