In working with this concept more and more, I've made certain revisions to pre-existing modules in order to make them more useful. The original cockpit module underwent a revision to bring the rear side technic bricks in line with the front ones (there was a one-plate offset initially). Similarly, the two 1x2 technic bricks w/2 holes on the Plasma Cannon (heavy weapons) module have been lined up (they, too, had a one-plate offset.)
Additionally, I've created three folders on my servers where these files have been uploaded. One folder holds all the individual
modules that I've developed thus far, one holds the
configurations that I've developed using those modules with each module color-coded for easy selection/manipulation, and one folder that contains all
designations, those configurations that have been named and 'painted'.
PLM-T1 "Bakemono" Rev. A by
vynsane, on Flickr
This revision of the "Bakemono" class interceptor uses separate weapon and engine modules.
LDD Files
"Kitsune/Hiyakudori" class light interceptor by
vynsane, on Flickr
An Alien Defense Unit "Kitsune/Hiyakudori" class light interceptor patrols the airspace of planet Earth for any signs of otherworldly trouble.
To increase the effectiveness of any weapon or sensor modules installed, the addition of a secondary cockpit module can facilitate seating a Combat Systems Officer who would then be responsible for monitoring the systems secondary to piloting the craft.
The fly-by-wire nature of the modular starfighter system allows for transference of duties from one control module to the other, so if something were to happen to the pilot, the Combat Systems Officer could take over control of the craft to land safely in a "limp home feature" capacity.
LDD Files
While JudahMoTron revealed his 'Trainer' version:
Modular Fighter - Trainer Variant by
JudahMoTron, on Flickr
I was also working on a tandem-cockpit variant of the "Kitsune" class light interceptor configuration. Originally I intended to make the additional cockpit module fit between the original cockpit and rear fuselage modules, but for the sake of a smooth appearance ended up incorporating the additional cockpit into a lengthened version of the rear fuselage.
