Hi, new to LEGO.
Quick question on the UCS. I have read two different versions, that these are, and are not, in mini fig scale. It looks like the shuttle is, but the new b-wing is not. Can someone help me get this straight? If they are all not to minifig scale, which ones are?
Thank you!
Newbie question oN UCS
- hatcher
- Location: Barrie, Ontario, Canada (aka The Great White North)
Re: Newbie question oN UCS
Minifigure scale is not so cut and dry. The Imperial Shuttle and the MIllenium Falcon came with minifigures that fit in the cockpits. The Super Star Destroyer has minigifures that come with it, but its not the same scale as the other two. In fact, I don't even think the Falcon and the Shuttle are in the same scale to each other. These are the only three that I can think of that come with minifigures that you can actually put in them. The B-wing does not come with figures and is not considered minifigures scalse mainly due to the fact that the cockpit is too large. Most of the other ships that cam before where like that as well, the cockpit area was larger then what you would need for a mini figure. So, if by minifigure scale, you mean that they are designed to fit minifgures in them, then the only ones that would qualify would be the Shuttle, the MIllenium Falcon and the Super Star Destroyer. Unless I have forgotten something.
Hope that helps.
Hope that helps.
Who is General Failure and why is he reading my hard disk?
Yes it does! Thanks!
