First Legoland Water Park opening june?
Discuss about retailers that carries LEGO products here! Got a LEGO Product Find or Polybag Find from a store? Share it with us. It can be a new or even a really old retired set!
vynsane
TnB Forum Moderator
TnB Forum Moderator
Re: First Legoland Water Park opening june?
Post by vynsane » Fri Apr 23, 2010 6:23 pm
I'm interested in seeing how they shoe-horn the LEGO concept into the water park concept. That 'build-a-raft' sounds like it will either be quite dangerous, or not all that customizable.
ALL HAIL THE BLACTRON EMPIRE!
Flickr Photostream | Dropbox - LDD files and instruction archive
JabbaT
Post by JabbaT » Sun Apr 25, 2010 3:53 pm
Interesting especially the build a raft. I look forward to this.
hatcher
Location: Barrie, Ontario, Canada (aka The Great White North)
Post by hatcher » Wed Apr 28, 2010 6:30 am
I don't know about this. I imagine a water slide made from LEGO would be rather hard on your body as you went down, what with all the little studs bumping into you as you went, not to mention that LEGO is not exactly water tight, I imagine they'd lose a lot of water going down.
And building your own raft for the raft ride? That could take hours, or even days, even if you used the biggest bricks they have.
(The above was completely tongue in cheek, I know they won't use LEGO to make the water slide or rafts, just wanted to have some fun.)
I will have to take my kids to this someday when they are older, sounds cool.
Who is General Failure and why is he reading my hard disk?
vynsane
TnB Forum Moderator
TnB Forum Moderator
Post by vynsane » Wed Apr 28, 2010 10:11 am
hatcher wrote:I don't know about this. I imagine a water slide made from LEGO would be rather hard on your body as you went down, what with all the little studs bumping into you as you went[...]
Only if they used standard studs-up technique. If they use some SNOT or a whole lot of tiles, it should be smooth. ;)
toystest
Post by toystest » Wed Apr 28, 2010 10:46 am
This should be our next contest... Design a Lego water slide
