Since my childhood I've always wanted to built a big airplane as close as the real one with fancy functions like flaps, landing gear, doors.....at first I thought I could built it in Technics and get all these functions motorized but I thought it would have been too complicated and too expensive. So no Technics just Lego (well actually it's not completely true...you'll see)
I started this project last April on LDD, Why on LDD because I moved in Canada in 2009 leaving my 2 big box of Lego in France. SO without any parts here I decided to design it on LDD and then order parts on bricklink.
First with some LDD screenshots:
Hello
I started this project last April on LDD, Why on LDD because I moved in Canada in 2009 leaving my 2 big box of Lego in France. SO without any parts here I decided to design it on LDD.
The main landing gear. The doors are pretty close to the real ones
Extended
Extended - doors opened
Retracted
Inboard flaps retracted
Inboard flaps extended
Now let's see the real one. Actually just the beginning
Sorry I just add links for the picture because they are from my gallery and too big for the forum (too bad 800px width would have been perfect
The wings with 2 complete engines and 2 engines partially done, slats (leading edge flaps), inboard flaps partially done and main landing gear (without wheels)
http://hysotpics.free.fr/photos/picture ... ategory/56
You can notice that the wing has an upward angle like the real one. To realize that I built a special center wing box:
Here is the version 1.0 waaaay to weak
and here is the version 2.2 way better:
You can see the nice wing bend (I just love it :) ) with the slats retracted
Slats extended
The version 1 of the engine, to weak also (the fan was not mounted yet)
Thrust reverser closed
Thrust reverser opened
I reinforced the inside of the engine and still working on the improvement of the cowling
here a version 2 of my cowling:
I replaced the bricks 1x1x4 white and 1x13 white by plates 1x4 white and 1x3 white
The inboard flaps still at an early stage, just to confirm the design
I recently started the fuselage
You can check more pictures on my flickr gallery (Some of them are showing old configuration - I made a bunch of modifications since then)
http://www.flickr.com/photos/yoansoilen ... 816995468/
or my personal gallery hysotpics.free.fr
The plane will show Air France paint
