Removing UV oxidation off tiles
Every week, a LEGO(My Own Creation) posted here will be featured on our front page. Got a cool creation? Share it! This is also the place to share your building tips and ideas as well as LEGO IDEAS.
Neo
Post by Neo » Sat Jul 27, 2013 5:57 pm
If you leave Lego in the sunlight for too long it may start to yellow.
The yellowing of grey and white lego tiles is very noticable and because it is due to the oxidation of the plastic surface - normal cleaning agents like oxyclean, bleach, rubbing alcohol, ammonia, or soap will not work. Using abrasives and an ultrasonic cleaner do not work either.
The only solution I found that work is Acetone. It is very powerful solvent and only a drop or two on a rag is needed to clean a 2 by 2 Lego tile. Just rubbing the tile with the rag for less than 5 seconds is enough to restore the tile's color. Use too much Acetone and it will melt/craze/scar the plastic surface making the Lego part unusable. Does anyone know of a milder solvant?
Brickbuilder0937
TnB Forum Moderator
TnB Forum Moderator
Re: Removing UV oxidation off tiles
Post by Brickbuilder0937 » Sat Jul 27, 2013 8:02 pm
Put the yellowed pieces in a container of hydrogen peroxide (the stronger the better) with a little oxy-clean mixed in, shine a UV lamp on the pieces for a few hours while they are still in the solution and they should come out looking like new.
dr_spock
Post by dr_spock » Sat Jul 27, 2013 9:58 pm
Acetone will also work as a ABS plastic glue if you want to glue Lego together.
Neo
Post by Neo » Sun Jul 28, 2013 9:13 am
I did try 3% hydrogen Peroxide (Drugstore variety) - it didn't look like it was working - but then again I only gave it a minute or two to work. Oxyclean has Hydrogen Peroxide in it so additing it to 3% hydrogen Peroxide solution raises its concentration level. :think: From what I understand, Food Grade +35% Hydrogen Peroxide is considered HAZMAT - and :shock: a 70% solution of Hydrogen Peroxide is consider to be rocket fuel. ... :eek:
Hydrogen Peroxide sounds more powerful than the Acetone solvent I am currently using. :shock:
Brickbuilder0937
TnB Forum Moderator
TnB Forum Moderator
Post by Brickbuilder0937 » Sun Jul 28, 2013 2:38 pm
I didn't know you could get it that strong, I think about 12% is strong enough.
JaumeBCN
Post by JaumeBCN » Wed Jul 02, 2014 9:48 pm
You guys can use hair decolorator (it's two creams, on with Hydrogen Peroxide and another one that is an 'activator' with ammonia) its what girls use to hide body hair.
